report generation toolkit help
I have created a simple example to demonstrate my needs.
Is it possible to write 16 numeric values (from my 16x for loop) “press and temp”, to my new report (from my defined template).
My two main issues are:
Each time it iterates through the loop, it floods the defined ranges with the same press and temp values. As I have defined my range as being 16 deep, i would like each iteration of the loop to incrementally populate the next available cell only.
Considering the above i would also only like one excel book to be opened then populated incrementally. What is happening just now is, for each iteration of the loop it creates a new book. Which, to be honest is what I expected to happen, but not the behaviour im looking for.
Any ideas?
Many thanks
(3,150 Views)
Accepted by topic author labnoob
ok,I worked away at this a found the solution to my own problem, pitty i cant give my self some kudos love 🙂
anyway, i have attached my solution in case anyone else finds this useful
Cheers
(3,116 Views)
hello, i am having the same problem/.. however i have labview 8.0, can you please repost in LV 8.0 version?
Now on LabVIEW 10.0 on Win7
(3,074 Views)
Hi, I tried to do this for you, however i kept getting errors during conversion. Think its to do with the RGT version not liking being backward converted.  anyone else able to do this for CrackJack?
(3,055 Views)
