08-12-2008 11:43 PM
08-13-2008 08:50 AM
The refinded versions of the express VIs are on the Signal Processing palette. You should learn how to use these (especially since you are apparently looking for a job programming LabVIEW).
Since you don't mention what this 'something' is that you want to do with the tone, I don't know how anyone can answer your question. You can view the new features in LabVIEW 8.6 yourself by going to http://www.ni.com/labview86/upgrade.htm.
