Does MT LDPC Encoder work properly??
 But the results are quite different. However, if I use the same encoded word and pass it through MT LDPC Decoder VI and decode() in Matlab, the results are just the same. The MT LDPC Encoder VI seems not work properly. Does any one know anything about it?
The encoded word has the format of [msg bits| parity bits], and comparing the results of labVIEW and Matlab, the msg bits are quite the same (sometimes slightly different), but the parity bits are different. And after the decoding process, the outputs are just different.
(3,044 Views)
Hi TIMFTS,
What version of LabVIEW are you using?  Also what addon or driver is this VI a part of?  There aren't any VIs in my palatte that contain MT LDPC anywhere in the name or description.
David A
(3,013 Views)
