Quick drop with Quick Drop
Hi!
When an item has been selected with Quick Drop is there a way to drop it on the block diagram or front panel using a keyboard shortcut?
Thanks!
Marco
Message 1 of 14
(5,207 Views)
With the item highlighted, just click on the Block Diagram / Front Panel!
_____________________________
- Cheers, Ed
Message 2 of 14
(5,201 Views)
I was asking for a keyboard short-cut 🙂
Message 3 of 14
(5,197 Views)
You can hit enter, but you still need to use the mouse to place the item where you want it
EDIT: Unless I am unaware of someone writing a QD add-on for a keyboard quick drop quick-drop. Nice idea.....
QD Enthusiasts
- Cheers, Ed
Message 4 of 14
(5,195 Views)
If you don't use the mouse, how would you specify (via a keyboard gesture) where on your diagram you want to place the object?
Message 5 of 14
(5,170 Views)
I suppose he could write a plugin for a shortcut and just get the visible part of the BD and drop it right in the center every time...I don't see why clicking is that much of a hassle though, especially since this way you can drop it right where you want it.
Message 6 of 14
(5,157 Views)
It seems to be that the OP wants to keep quick drop open.  So basically choose you function, drop it down, select another function, etc. all without closing the quickdrop.  Seems like it would just create a mess on your block diagram to me.
Message 7 of 14
(5,150 Views)
We talked about this idea in this thread on the Quick Drop Enthusiasts forum. My vision is that, after dropping an item by clicking in the VI, Quick Drop would remain open and reacquire focus, so you could start typing another object name again.  As I mention in the thread, it's an idea I've prototyped, but haven't been able to get working quite right.
Message 8 of 14
(5,125 Views)
Select the wire (or wires) you want to attach the item to, open Quick Drop, select your item, then press Ctrl-I (Ctrl-Shift-I for multiple wires); the selected item appears on the block diagram connected to your selected wire(s) without any (more) mouse clicks. However, Quick Drop closes, making this not such a convenient feature in my opinion. If you don't like the Quick Drop closing, join this conversation: Keep Quick Drop open - Idea Exchange.
Matt Kirk
Inventor of ImageJVI
Message 9 of 14
(5,117 Views)
To be clearer, I would like to do the following:
1) Place the pointer of the mouse where I want to place the function
2) Open quick drop
3) Type the name of the function I want to insert
4) Press a key and have the function placed in the block diagram at the position of the pointer.
What I'm doing now is
4a) Press enter and have the function "floating" on the block diagram ready to be placed
4b) Click the mouse button to place the function on the block diagram
Avoiding this mouse click could help save time when coding.
Marco
Message 10 of 14
(5,082 Views)
