Does Mobile Module 2011 supports Windows Mobile 6.5
http://digital.ni.com/public.nsf/allkb/4AF5A9916DA9D83B8625797B0061CD1E
In this article, it lists that Mobile Module 2011 only supports
  • Pocket PC 2003
  • Windows Mobile Module 5.0
  • Windows Mobile Module 6.0
and will not be able create app that runs on any other OS.
Well, I have a handheld which loads Windows Mobile 6.5. I deployed a program to it and the program runs fine. So does this mean the WM 6.5 is supported as well? Or I am just lucky?
(2,656 Views)
Accepted by MengHuiHanTang
6.5 is technically probably close enough that it could run, and your test seems to indicate it can. However NI likely never tested 6.5 and therefore you will be on your own here. If it works it's great, if it doesn't you won't get much of support as the Windows Mobile Module is discontinued now.
Rolf Kalbermatter  My Blog
(2,642 Views)
