Does Universal Library Extension works for LabVIEW2011?
I just installed LabVIEW2011 and seems that I cannot loaded the VIs in the Universal Library Extension from Measurement Computing Corp. Is this library compatible with LabVIEW2011? Is there anyone also has the same problem? I tried to check the website of the Measurement Computing Corp, but the website is down and I cannnot open it.
Thanks!
(3,868 Views)
Accepted by Xiangshi
I ran into the same problem as you.  The answer from MCC technical support was they don't support LabVIEW 2011.  We found a way to get around it though.  You can install the MCC CD on a computer with LabVIEW 2010 or lower.  Copy all the folders and files pertaining to MCC to your computer with LV2011.  Remember to check
C:\Program Files\National Instruments\Shared
C:\Program Files\National Instruments\LabVIEW 2011\user.lib
C:\Program Files\National Instruments\LabVIEW 2011\vi.lib
C:\Program Files\National Instruments\LabVIEW 2011\resource
I recommand doing a window file search.  Or you can install LabVIEW 2010 or lower.
Kudos and Accepted as Solution are welcome!
(3,844 Views)
Thank you very much for your help! It works now with your suggestions 🙂
(3,828 Views)
No problem.  I just had the same problem in less than a week ago, so it is still fresh in my mind
(3,815 Views)
