Does VMIC driver support LV RT8.2?
Using VMIC-5565 instrument driver for LV, I am trying to setup reflective memory VMIC-5565 on LV RT 8.2. My problem is how to setup VMIC-5565 on RT and it is not detected on MAX.
First, after installed the driver which is provided from GE FANUC, I traced Driver Installation steps on Readme.rtf with below driver VIs components.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E919C659CE034080020E748...
Second, I rebooted Host PC. Third, based on the below topic, I transferred V65_d_RT.inf or v65_n_RT.inf file into /ni-rt/system/ on PXI RT via FTP and rebooted PXI.
http://forums.ni.com/ni/board/message?board.id=170&message.id=205697&query.id=518780#M205697
However, LEDs on VMIC-5565 did not turn on and the board was not detected on MAX. What is the cause of the problem? What else should I do in next?  Some topics regarding VMIC-5565 on NI web are helpful to me, but if there are any other actions to setup it, please let me know. I hope that I will hear from you sometime soon.
My PXI configuration :
PXI-1042Q
PXI-8106RT
VMIC-5565 (GE FANUC Reflective memory)
LabVIEW 8.2, LabVIEW RT 8.2
NI-VISA 4.1, DAQmx 8.5.0f3
Tsugo
Message Edited by tsugo on 05-02-2007 05:10 AM
(3,287 Views)
I'm using VMIC-5565 card with Labview Real Time. At the beginning, ı have also some problems but now it works well. I use real time deskop not a PXI controller, but perpaps i can help.
First of all, you said "after installed the driver which is provided from GE FANUC"
You shouldn't install any driver except supplied from NI web page. In your case, you have two driver in your computer; one is provided by GE FANUC and one is gotten from NI webpage,. They are NOT used together. ( most probably your operating system is congused because of the multiple driver)
So you need to uninstall one (provided by GE FANUC) and try again
(3,163 Views)
