VI not correct? Build Path
I would like to have confirmation that this VI is not correct please.
Normally, a path and the name of a file is build to write in this file, but  we build only a path and the output is someting like path\name of the file\
and then is is not possible to write in this file, isn't it?
So I should replace the function Build Path by soemthing else?
Thank you.
Regards
(3,939 Views)
sorry... i read your post several times and I still don't know exactly what's your question.
Can't you post another point of view or made a simple example?
Software developer
www.mcm-electronics.com
PORTUGAL
(3,926 Views)
A guessSmiley Wink
If you are building the file path as a string, you will have to use a convert 'string to path' function as shown in the attached vi
Message Edited by devchander on 05-31-2007 05:16 AM
(3,924 Views)
I forgot to attach the VI...sorry.
My problem is:
With the function "Build Path", a slash is add, I will try with the function String to Path.
Message Edited by ENSTB_Vivien on 05-31-2007 07:24 AM
(3,911 Views)
Ok, it was another mistake that add a slash, sorry for the post.
(3,902 Views)
ok,
So the problem it's solved and you don't need help.
Bye
Software developer
PORTUGAL
(3,894 Views)
Hi ENST...,
why do you format the filename that complicated?
You can do it like this:
Message Edited by GerdW on 05-31-2007 04:05 PM
(3,890 Views)
