Does Web UI Builder support the DSC Module?
A simple question:
Can I use the Web UI Builder for a Web-client-access at a Windows-LabVIEW-System with DSC module or supportet this UI tool only the basic LabVIEW features for front panel objects?
For example: Can I use a web client to look into historical data and alarms? Can I use a web client with full support of "Front Panel Security Dialog Box" (see http://zone.ni.com/reference/en-XX/help/371618F-01/lvdsc/front_panel_security_db/)?
Best regards
Frank
(3,580 Views)
Accepted by topic author herbrand
Hello Frank,
Yes, you can use Web UI Builder to access historical data and view current alarms. The LabVIEW 2010 version of DSC has several built-in RESTful web services that make Citadel and alarm data available via HTTP. Below are some resources to provide the details on how it works.
Interacting with DSC Module Web Services
Here's a an example that illustrates how implement the web service communication to Citadel:
Database Communication via Web Services in LabVIEW Web UI Builder
Mike
(3,563 Views)
Michael,
Many Thanks!
(3,560 Views)
This sample VI shows how to access historical data.  Does anyone have an example of using Web UI Builder to access current alarms? ie, Web Service nialarm?
G Zimmer
(3,367 Views)
