array string path
I am using the development vision,
I've got a table and in the fourth column of this table, there are some addresses that I need to open separate them individually.
How could I get these addresses on separate strings and transform each of these addresses "string" to "Path"
Thank you.
Message 1 of 8
(4,043 Views)
There is an String to Path function.
Message 2 of 8
(4,040 Views)
Ok,
but I want to separate the lines of the colum in different strings, ofr after i convert String to Path.
EX:
 address
aaa
bbb
ccc
ddd
Address                Address                      Address                Address                   Address          Address
aaaa                    bbbb                             ccc                         ddd                      eee                  fff
But Thanks so much....
Message 3 of 8
(4,037 Views)
Get the string from the last column and use Spreadsheet String To Array Function with a delimiter of carriage return/linefeed
Message 4 of 8
(4,030 Views)
i'm sorry, but i don't know how can i get the string of the last column.
Check the attachments with example.
And said for me how can i get the last column string, please.
Message 5 of 8
(4,027 Views)
I can't open the VI since I only have LabVIEW 8.6.
Message 6 of 8
(4,022 Views)
I´'m sorry..
See now the attachments.
Message 7 of 8
(4,018 Views)
Use the Index Array function to get just the column that you want. This will give you a 1-D array of the text in that column.
Message 8 of 8
(4,011 Views)
