Does a tutorial come with LabView Professional?
Does a tutorial come with LabView Professional? If yes, does anyone have comments on it's usefullness for a first time user? A class or the $500 CBT's may not be an option at this time.
Chris
(2,602 Views)
There is a pretty good tutorial shipped with LabVIEW.
Fire up LabVIEW, go to the 'Help' menu and select "Search the LabVIEW Bookshelf". This will open a PDF that actually lists all the documentation that ships with LabVIEW and all related modules. There's even a search function so you find what you're looking for. Anyway, look for a link on the page titled, "Getting started with LabVIEW". This is the tutorial and will go through all the basics you need to know to get you started.
Keep this "Bookshelf" in mind and use it. It's full of all sorts of good information.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,598 Views)
Ed,
I appreciate you post. We're excited about bringing Labview to our organization.
Chris
(2,589 Views)
Also check the resources available at the LabVIEW Learning Center. There's on-line tutorials and books galore.
(2,582 Views)
