Does a vi called by two executables need to be reentrant ?
Hi everybody,
this seems to be a newbie question, but this is the first time i'm in this case...This vi store some values in shift registers. The built application (exe format) that call this vi is then duplicate in two folders with different ini file, and they're running at the same time : is it necessary for the vi to be reentrant ?
Thanks for any help,
Vincent
Vincent
(2,434 Views)
Accepted by VdG
No, it doesn't need to be reentrant. Each compiled exe will use its own version of the VI.
(2,427 Views)
Ok, thanks Dan,
Vincent
(2,412 Views)
