Does anybody know how to pass images from DVT framework 2.6.1 to LabVIEW 7.0?
I have a DVT camera running inspections and a Laptop running Framework 2.6.1, I have the ActiveX Controls version 1.2.2 and I can communicate with Visual Basic 6.0 but not with LabVIEW 7.0. I am using an Automation Refnum pointing to the DVT SID and invoking the methods to connect, display images and disconnect, but out of the Automation Refnum, I am getting a 0 value which is genarating an error 97 in LabVIEW. The question is, Does somebody knows how to do it right?, or if there are known issues that will not allow it?
Thanks in advance ...
(3,363 Views)
Violante,
I did some basic research into this and you can view the results i obtained
here:
http://www.lavausergroup.org/phpBB2/viewtopic.php?t=74
hopefully this will help
Regis
"violante" wrote in message
news:50650000000800000056AD0000-1066448259000@exchange.ni.com...
ght?, or
(3,363 Views)
Greate answer, it works fine now!!. Thank you.
(3,363 Views)
