Does anyone have any details about Wi-Fi- DAQ?
Hello Everyone,
                      Does anybody know how to use the Wifi DAQ?? Do I need a wireless network already set up where I should place this wifi DAQ and then use it?
I see the protocol is 802.11 b/g... so, would it require a modem/router  generating a wireless n/w?
Please let me know...
http://www.ni.com/dataacquisition/wireless/
Now on LabVIEW 10.0 on Win7
(3,075 Views)
Hi CrackJack,
Yes you will need a wireless network to use WiFi DAQ. You can set up an Ad-Hoc network with a computer that has a wireless card and use the device that way. You don’t necessarily need a modem/router etc. if you use this method. NI.com/gettingstarted is a great resource for questions regarding device setup and use. Check out this page on the wireless DAQ setup and configuration.
About half way down there’s a section that addresses the wireless needs of this device.
Matt
Applications Engineer
(3,048 Views)
thanks a lot Matt
(3,031 Views)
I had one more doubt... does the wi-fi DAQ support analog outputs?
(3,010 Views)
Hi CrackJack,
Unfortunately, the AO C-series modules don’t appear to work with the WLS 9163. Take a look at this document which shows some compatibility information.  A compact DAQ chassis will support AO cards, and there is an Ethernet version of that out, NI cDAQ-9188.
Matt
(2,995 Views)
