09-28-2010 04:19 PM
Hello Everyone,
Does anybody know how to use the Wifi DAQ?? Do I need a wireless network already set up where I should place this wifi DAQ and then use it?
I see the protocol is 802.11 b/g... so, would it require a modem/router generating a wireless n/w?
Please let me know...
http://www.ni.com/dataacquisition/wireless/
09-29-2010 11:52 AM
Hi CrackJack,
Yes you will need a wireless network to use WiFi DAQ. You can set up an Ad-Hoc network with a computer that has a wireless card and use the device that way. You don’t necessarily need a modem/router etc. if you use this method. NI.com/gettingstarted is a great resource for questions regarding device setup and use. Check out this page on the wireless DAQ setup and configuration.
About half way down there’s a section that addresses the wireless needs of this device.
09-29-2010 05:08 PM
thanks a lot Matt
09-30-2010 04:47 PM
I had one more doubt... does the wi-fi DAQ support analog outputs?
10-01-2010 01:39 PM
Hi CrackJack,
Unfortunately, the AO C-series modules don’t appear to work with the WLS 9163. Take a look at this document which shows some compatibility information. A compact DAQ chassis will support AO cards, and there is an Ethernet version of that out, NI cDAQ-9188.
