Does anyone know how to control the font characteristics of an array with a front panel control?
This seems like it should be pretty simple.  I want the user to be able to adjust the font characteristics of an array of numbers using some controls on the front panel.  I know how to do this using the drop down menus - but I want my users to do all with the front panel controls.  I looked at the property node options and it didn't look like anything in there would help...
Thanks for your time.
j.
(3,057 Views)
Accepted by topic author PA_UW
Right-Click on a Numeric Control Inside the array and choose Create->Property Node->NumericText->Font->Size.  Change to Write and use this to adjust the size on the fly.
(3,050 Views)
Thanks so much - so easy - I appreciate it!
j.
(3,039 Views)
Giving Darin a kudo and marking his reply as the solution would be a good way to show appreciation.Smiley Wink
(3,033 Views)
