Does anyone know of a way to highlight, or even change the background color of, one item in an array?
I have an array of words that a user can scroll through and I would like to be able to show which word the user is currently on.
Joe
Frustrated Student
(2,892 Views)
Hi Joe,
use an Listbox to highlight the selected entry. You can find it on the
list & tables palette. Just wire you array of strings to the created
property node itemnames. If the user selects now an element it will be
shown with a background you can specify.
Henrik
> Thanks,
> Joe
> Frustrated Student
(2,892 Views)
There's no way to highlight a specific item in an array.
But in your case you can use a listbox control/indicator, note that you can insert in it your array strings using the attribute nodes (property).
With a listbox it is very easy to highlight a specific item.
(2,892 Views)
If you want the 2d array look, you can use table instead of listbox. In table you can also specify the background color of a cell.
Jared
(2,892 Views)
