I am trying to plot two analog signals on the y axis vs. an analog signal on the x axis on an xy plot. If anyone knows how to do this or has an example vi showing it I would appreciate it.
I think the best starting point for you is the XY graph.vi example. You will locate it in examples\general\graphs\gengraph.llb directory. The example that most probably matches your needs is '(X and Y arrays) Multi Plot' graph. Hope it helps Roberto
