Does anyone know why this may be happening?
My attached program was working fine, until I moved my computer. The I/O assistant reads information from an accelerometer connected via a serial port. Since the move, the program is not being able to read the port and is giving me an error code -1073807194. However this instrument is being read via the port using Hyper Terminal and the annemometers own software. Is there anything that Im missing?
Cheers, Sam
Message 1 of 20
(4,149 Views)
to Another computer?
Message 2 of 20
(4,092 Views)
I have had a go at going through the measurement and automation explorer, to see why it isnt working and when I try to validate it, it gives me the attached error message?
Sam
Message 3 of 20
(4,091 Views)
no, i just moved the same computer to a different location. I obviously had to detach all the cables out the back. Hasn't worked since then.
Message 4 of 20
(4,089 Views)
What is the timeout you have set? Check the cable. If it is a different pc check confirm the com port number.
Message 5 of 20
(4,088 Views)
Do you have Hyperterminal running? Only one application can (normally) access a serial port. So if Hyperterminal already uses the COM port LabVIEW can't access it.
Message 6 of 20
(4,085 Views)
close your hyper terminal If you have not done it before. You cannot simultaneously open hyperterminal and run lv vi.
Message Edited by muks on 08-18-2009 06:49 PM
Message 7 of 20
(4,084 Views)
Ah dan beat me by a split second on that...........:smileyvery-happy:
Message 8 of 20
(4,081 Views)
lucky me Smiley Very Happy
Message 9 of 20
(4,077 Views)
But, this time you beat him by 2 secs. Smiley Very Happy
- Partha ( CLD until Oct 2027 🙂 )
Message 10 of 20
(4,065 Views)
