Does labview have the capability of MIL-STD-1553 Communications
Please send sample programs for interfacing 1553 devices using labview
Message 11 of 14
(3,273 Views)
I used LabVIEW VIs and DLLs from the board manufacturers.
My code will not work with your boards unless you happen to use SBS or Ballard.
My suggestion is that you go to whoever your 1553 board vendor is and ask them
if they have LabVIEW drivers and example programs.
With both SBS and Ballard they did. Personally, I thought the Ballard drivers
were much better.
Message 12 of 14
(3,266 Views)
hummm...Old thread.... You guys still around?
I am interested in seeing a LabView application using the ballard 1553 card.  Can anyone post or send me something.
Thanks!
Message 13 of 14
(3,111 Views)
Hi Zylont,
National Instruments currently doesn't have an instrument driver available for this particular instrument (although you can always build up your own programs!)  From the sounds of it, if you're looking for pre-made examples and libraries at this time, speaking with Ballard directly might turn-up more for you.  Good luck!
Anna M.
Message 14 of 14
(3,090 Views)
