Does shared variable deployed on RT target holds its value after reboot?
The shared variables deployed on real time target are stored in RAM or non volatile memory? Will it hold its value after reset or power off/power on? I tested and it seems hold its value but I didn't find any documentation about it from NI.
Tom
(2,884 Views)
I had always assumed that shared variables would assume their default or inital value (if you are using the DSC)
http://digital.ni.com/public.nsf/allkb/7BA64956A475405F862570ED007B2A88
The deployment itself is stored in flash and is preserved when cycling power, but the actual value of the SV's is
in RAM and I would not expect it to be preserved.
(2,878 Views)
All shared variables revert to their 'default' values when the Shared Variable Engine is deployed.
(2,868 Views)
If the shared variable is redeployed after reset or power down/power up it do reset to its default value. But without redeployment it keeps its previous value, at least for the target I tested (sbRIO 9612).
(2,847 Views)
Accepted by tom_z
There are several components involved in how the variables are stored on a target but a portion of that is in non-volatile memory. Shared variables local to the RT target will not retain their value. Any host reading data from the target will receive the last value from the target prior to reboot considering that the host is not concurrently re-booted. The reason why is that there are 2 shared variable engines at work;one for the host and the other for the target. Since only the target was re-booted, the shared variable engine on the host will retain its last value while the engine on the target will be set to 0, false or empty string. Here is a Community example that  'Monitor'[s] for Empty State in RT FIFO Enabled Shared Variable'.
Best,
Applications Engineer
(2,837 Views)
Hi Patricia,
    Thanks! It explain what I saw.
    Tom
(2,822 Views)
