The function will return a value with a 1 ms resolution. The true resolution and accuracy of it is another question though. Try calling it twice with a wait in between that you vary and you'll get an idea...
If the function returns only integer seconds, and you say that this is to within 1 ms of some system clock, does this mean that the function comes back within 1ms of the report second finishing on the system clock?
It does not return an integer, it returns a 128 bit timestamp in LV7, in LV6 it returns a double precision floating point number. But all this is obvious, what is it you want to use the timestamp for and why does the accuracy and resolution matter. Knowing that we can tell whether there's a problem.
I have it now! Sorry to trouble. When the context help indicated that Get Date/Time returns the number of complete seconds, I assumed that it returned an integer. FORTRAN habits show up in the ugliest places. I now see that it returns info as you indicate. Thank you.
