Does the IXXAT CAN interface have a "Wait-state" capability similar to NI-CAN?
Greetings,
We have a IXXAT USB-CAN adapter, so I'm using their "driver" VIs, however...
I came across an NI-CAN Read SDO example that writes a SDO request then waits for "state" = 2 before reading a response.  I assume this waits for some CAN-bus state or status bit, and seems like a good idea, but I can't figure out what IXXAT VIs to use, to accomplish a similar wait(?)
Thanks/Cheers!
(3,930 Views)
Hi 550nm,
Where did you find these drivers? Were they on our IDNet page? Can you post a link to the driver package, or attach the VIs in question? Also, can you list the directory for the NI-CAN example you mentioned? I took a surf through the example finder but couldn't find the one you referenced.
Nick
Applications Engineer
(3,867 Views)
Hi Nick,
The NI-CAN example is found here.
The IXXAT "VCI" installer is here - it includes the USB/CAN adapter device-driver and LabVIEW examples.
Cheers!
(3,861 Views)
Hi Nick,
I _may_ have answered my own question...
On looking through the IXXAT "C-API" doc I found a function "canChannelWaitTxEvent".  In their LV wrapper DLL, there was a "lv_canChannelWaitTxEvent", though it was not represented in the IXXAT Channel VIs - so I made a VI for it.  It doesn't crash or hang LV and occasionally appears to wait for 300+ ms, though usually executes "instantly" (following SDO query message).
I'd still like to know exactly what the NI-CAN wait state (= 2) does!
Thanks/Cheers
(3,845 Views)
Accepted by 550nm
I was able to find this documentation on the function ncWaitForState on page 2-37 of the CAN manual. This is essentially a blocking function that waits for the desired state to be reached. A list of states and their numeric identifiers can be found in Appendix A (pp. A-1 - A-2).
"NI-CAN Programmer Reference Manual"
http://www.ni.com/pdf/manuals/370289c.pdf
Nick
(3,840 Views)
Hi Nick,
Thanks for the pdf!
The description of the '2' bit may indicate NI-CAN is waiting for the same TX event I described...
Indicates that all data provided using ncWrite has
been successfully transmitted onto network. Set when
last transmission is successful
Cheers.
(3,826 Views)
Glad to help!
Nick
(3,810 Views)
