Dot after unit thousands
I want to separate a number after each thousands unit as a dot or a comma.
For example, if I have 12345678, it becomes 12,345,678 or 12.345.678
Can anyone help me with this problem?
(3,248 Views)
Accepted by Vu_Anh
Unfortunately, LabVIEW doesn't have a format specifier to separate groups of 3 in a numeric display.  You'll have to do it with a string indicator.
I think I created a subVI to do this, but I can't find it at the moment.
I recommend voting for this idea.  https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Visual-Aides-Numeric-Separators/idi-p/941273
I found my VI, but it did more than just commas.  But luckily I put a note in it that told me where I got the heard of the code.
See https://forums.ni.com/t5/LabVIEW/How-can-I-format-a-large-number-to-have-comma-separators/m-p/322518...
(3,224 Views)
Thank you very much. It is what I need for my VI.
(3,204 Views)
Here is another way to do the same thing.
Tim
GHSP
(3,194 Views)
I recommend the link I posted above.  Tim's example only works with integers.  If you feed it a value with a decimal fraction portion, it will round it to the nearest integer.
PS:.  "Separator"
(3,164 Views)
I don't get paid to spell. : ) That is part of why I love LabVIEW. I try but one does slip through every once in a while.
Tim
GHSP
(3,160 Views)
