Double counting, possibly due to scan engine
I am using a NI-9145, with NI 9361 cards. I am using logic threshold 1V, single ended and digital filter of 1250 unit ticks (0.1ms). the cards are set up to detect rising edge. and give me the number of detections evertime i read with my timed loop
(synced with scan engine.) but occasionally even with a signal generator from an oscilloscope. im getting double pulses occasionally, its intermittent. this has led me to believe its the software on not any noise within the system. Is my timing set up incorrectly?
(227 Views)
The problem is that I am reading from the scan engine before it updates. That why my counter card is reading duplicate values.
How can i properly time this loop with the scan engine? I am following from the NI example "User-Defined Variable IO Scan Sync".
When moving the Feedback nodes from the FPGA side to the Realtime side, the repeated values, causing duplicates, no longer persists. But that also means I am reading from the scan engine before it has updated its values.
What can I do?
(172 Views)
Hi eli,
usually you can set a cycle time for the ScanEngine in the RT project.
You should limit your loop iteration rates below that ScanEngine rate...
(168 Views)
GerdW,
I have left it at the default of 1ms. Is this a bad design? Its a NI-9145 and cRIO-9049, top of the line. so it should be able to handle 1000hz.
I am considering moving the I/O Nodes from the Scan Clock "Wait on Rising Edge" Frame. IF that would eliminate the double reads from the cRIO end.
Unless you think I can just remove the "Wait on Rising Edge" entirely?
(141 Views)
GerdW,
Can you please clarify? Why shouldn't the Chassis (9145) match, or exceed the loop rate of the scan engine?
(51 Views)
Hi eli,
When I used the ScanEngine I was working with outdated cRIO9074 devices.
At that time you were bound to less than 100Hz sample rates for the ScanEngine: to avoid "double values" I also had to reduce the loop iteration rate the less (or same) as the ScanEngine rate. I didn't play with the "Wait on edge" functionality, so I cannot provide more help for your question…
In the end I placed all my DAQ code in the FPGA and got rid of the ScanEngine at all!
(38 Views)
