Double icons on taskbar when running a program created with application builder
Hi all,
When I create a stand alone executable with the application builder (6.i)
and subsequently run it, two icons show up on my windows taskbar. When I
click on either of them, the same executable is maximized. Why are there two
icons for the same program ? (is one of them referring to the LV runtime
engine ?). Is there a way to avoid this behaviour ?
Martien
(3,872 Views)
In the ini file for your executable create a section with the same name as the executable and put the follwing key in it:
HideRootWindow=True
That will get rid of the second Task bar listing.
Kelly Bersch
(3,872 Views)
Just to expand on the previous answer, the ini for the vi (My Vi.ini) would look like this:
[My Vi]
hideRootWindow=True
A great page listing most of the ini preferences is here:
http://labview.brianrenken.com/INI/
2006 Ultimate LabVIEW G-eek.
(3,872 Views)
Thanks to both of you,
I just tried it out, it works OK
Martien
"Jonnie 5" wrote in message
news:506500000005000000C3250100-1042324653000@exchange.ni.com...
> [My Vi]
> hideRootWindow=True
(3,872 Views)
