03-19-2013 07:17 AM
when generating and acquiring samples, the maximum sample rate is the maximum board sample rate divided between the number of generating and acquiring task?
thanks
Solved! Go to Solution.
03-19-2013 07:37 AM
03-19-2013 08:03 AM
Hello GerdW, thank you for your reply.
I am using the DAQPad6016 acquisition board which have a maximum sampling frequency of 200 kS/s. Initially i want to generate a excitation signal and acquire the response signal. So i am using an analog output for the waveform generation and analog input for the waveform aquisition. So in these terms i am not using the mux because as you said they are separated task.
so these means that i can generate and acquire to the maximum sampling frequency (200 kS/s) for each one of them?
thank once more time.
Houari
03-19-2013 08:36 AM
Hi Houari,
you should read the specs of your DAQpad more carefully!
It clearly says: Analog inputs = 200kS/s samplerate, but analog outputs = 300 S/s sample rate or just even 50S/s for hardware timing!
03-19-2013 08:38 AM
Thank you very much. I really did not perceive it. I see the hardware wil not work well enough.
Thank you very much, really
Houari
