Doubt regarding coding in LabVIEW
Why don't my code run continuously for 5 iterations? I've started learning the language since 2 days so this question might well be silly.
(4,109 Views)
Accepted by Ganny
It does, but each loop does exactly the same thing so you will only see one result.
(4,105 Views)
And if you want all the output of the 5 iterations, keep the indicator out of the loop 🙂
Mathan
(3,962 Views)
A tip is to activate the Highlight execution-light bulb to see in slow motion what's happening. In this case you'd see it loops several times e.g.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,937 Views)
This worked. Thanks man 🙂
(3,918 Views)
