Down converting labVIEW 2015 projet files for LabVIEW 2013
What is the procedure for down converting labVIEW 2015 projet files into LabVIEW 2013.
Project files include VIs and dependencies (user libraries and lvstorage.dll).
Regards
(3,534 Views)
Hi Jamal,
On the project explorer click File >> Save for Previous Version...
(3,527 Views)
Hi Jamal,
File menu -> "Save for previous"…
(3,524 Views)
I have done in the same way as File menu -> "Save for previous versions" but when I open the project it says dependencies are loaded from another location and VIs do not work.
(3,489 Views)
Accepted by Mr_Engineer
I'm using LabVIEW 2014, could you save something for 2014 or previous and upload the output? Just create a new folder on your desktop called something like "Project (2014)" and when you save for previous make sure you are in the folder and click Current Folder. Then compress it into a zip folder and upload it here.
(3,477 Views)
