Downconvert Soundcard Microphone Input
I would like to read a modulated sound with my soundcards microphone and then downconvert & demodulate it. However, when reading the sound using the Sound Input Read.vi, I get a 1D array of a waveform (dbl), while the downconversion.vi expects a waveform(dbl). How can I transform this 1D array to the expected format?
Thanks in advance,
Markus
(3,001 Views)
You should be able to use the Index Array function. It will default to index of zero, and should return a waveform...
(2,987 Views)
