Access denied message
I get the following message when trying to connect to a PXI controller running Labview RT 8.6
"Access denied: This host computer's IP address is not on the target's allowable access list."
I entered the controllers properties whithin the Labview project, selected the user access list and added both the IP address of the host PC and *, but still get the error. Reset the PXI system and the PC, no change.
Is there something else I need to do?
Dave
(4,316 Views)
What happens if you try it from another project?
Jeremy_B
(4,271 Views)
Jeremy,
I created a new projected, selected the RT system and still could not connect.
(4,268 Views)
Can you see the system in MAX?  If so, reformatting it and reinstalling the RT software.
Jeremy_B
(4,240 Views)
Thanks Jeremy, I was able to get help via email. The problem was with the ni-rt.ini file. The tokens pertaining to user access were not correct.
  server.tcp.access="+*"
        RTTarget.IPAccess=+*
Dave
(4,227 Views)
Hi Dave,
Glad it is working now, thanks for posting the solution!
Jeremy_B
(4,210 Views)
