Downconvert VI Requests
Hi Guinness,
here it is in LV8.6!
Message 41 of 1,444
(5,092 Views)
Thank you very much!!
Message 42 of 1,444
(5,089 Views)
I was doing some work at home on a labview 9.0 trial but at work we only have 8.6, any help would be appreciated.
Source:  LabvVew 9.0
Target:   LabView 8.6
Message 43 of 1,444
(5,057 Views)
Hi adamvs,
it's LV8.6 now.
Mike
Message 44 of 1,444
(5,050 Views)
Attached is in 8.6. I don't know what the intention of the VI is, but you should be aware that your VI has a fundamental flaw: You should not use both the N terminal and autoindex a for-loop. The lower value (N, or the number of elements in the array) will win as far as the number of times the loop runs.
Message 45 of 1,444
(5,050 Views)
Thank you.  It couldnt actually ever be a problem, but thanks for the heads up.
Message 46 of 1,444
(5,044 Views)
If possible, would someone please convert TestVI.vi in ftp://ftp.ni.com/pub/devzone/tut/test-scripts.zip
Source version: 8.6 (or so the error message says)
Target version: 8.2.1
Thanks!
Ryan
Message 47 of 1,444
(5,011 Views)
Hi Ryan,
here it is.
Mike
Message 48 of 1,444
(5,002 Views)
Thanks Mike!
Message 49 of 1,444
(4,985 Views)
could someone please convert the following driver from labview 9.0 to labview 8.2.1? I tried to download the 8.2 version from the drivers page (http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0470714759413BCCE0440003BA7CCD...) by clicking on the LabVIEW 8.2 "Download Driver Now" Button but got the version for labview 9.0.
Thanks a lot.
Best reagrds,
Michael
Message Edited by MichaGue_01 on 03-26-2010 02:24 AM
Message 50 of 1,444
(4,966 Views)
