Downconvert VI Requests
Thanks for the previous downconvert. I now have a different one that I need. The original version is 9.0 and I need version 7.1. Thank you everyone who helps.
Message 251 of 1,444
(2,210 Views)
Hello, Can someone convert these two VIs from LV 2009 to v7.0 for me?
thanks!
Message 252 of 1,444
(2,194 Views)
I no longer need mine downcoverted. Thank you!
Message 253 of 1,444
(2,189 Views)
Can someone please help me down-convert the following file from 9.0 to 7.1
Thank you,
Mac
Message 254 of 1,444
(2,164 Views)
Try the attached VI and let me know if it worked.
Stephanie A.
Americas Marketing Manager
Message 255 of 1,444
(2,144 Views)
Hi, could you please downgrade this VI from LV 2009 to LV 8.6 for me? Thanks Robert
Message 256 of 1,444
(2,123 Views)
Thanks Stephanie! it worked out great
-Mac
Message 257 of 1,444
(2,110 Views)
Robert,
Here is the VI downconverted for LV 8.6. It is broken because I do not have the Starten Daurch Mauskombi Initialisierung (SubVI).vi. If you have this subVI and need it downconverted as well, just reply to this post.
Have a great day : )
Stephanie A.
Message 258 of 1,444
(2,100 Views)
Attached should be in 8.6. I'm assuming you have the subVI it was looking for "Starten daurch Mauskombi Initialisierung (SubVI)" (why they felt it necessary to add "SubVI" to the name of the file makes no sense to me.
Message 259 of 1,444
(2,098 Views)
thank you both! Working fine.
It's because the other file is orignal written in 8.6 ... sorry for that 🙂
Great help & fast =D
Cya
Robert
Message 260 of 1,444
(2,090 Views)
