Downconvert VI Requests
I am in desperate need of this vi tree downconverted from 7.0 to 6.0.  I Don't have access to the previous two version required to down convert.  Is there anyone out there that could down convert this to v6.0 for me?  You will be my hero!
Kevin Lyon
Message 1281 of 1,444
(1,832 Views)
As has already been explained to you, uploading the .lvlib file, or uploading a "VI Tree" does not "automagically" include the subVIs. Just like in a text-based language, uploading one code file does not "automagically" include any other code file is "#include(s)". I have no idea of what use a VI tree would be to you without the subVIs, and if you had the subVIs, then it would be a trivial matter to simply re-create the tree.
Message 1282 of 1,444
(1,824 Views)
Ahh...Now I understand what you were saying.  Sorry about that.  Here is the folder with everything in ver7.0.  I need it converted to 6.0 (or at least the stuff that shows up in the tree file.)  All of the required files should be in this zip folder as I can open the files and use them on a 7.0 machine.
Kevin Lyon
Message 1283 of 1,444
(1,813 Views)
I need to convert a WIN Buffer to an Array.  Could someone please convert this file from Ver . 8.0 to Ver. 7.1.  Thank you
Message 1284 of 1,444
(1,806 Views)
Kevin Lyon
Try the attached
Message 1285 of 1,444
(1,803 Views)
Can somebody please convert these drivers from 8.5 to 8.2.
Message 1286 of 1,444
(1,802 Views)
Thank you so much for the down convert and now I know what the tree file actually is!  I am still at the beginning of the learning curve.
Kevin
Message 1287 of 1,444
(1,788 Views)
Can someone please convert this 9.0 program to 8.2.  Thanks
Message 1288 of 1,444
(1,766 Views)
I need the file in LV7.1
KB29
Message 1289 of 1,444
(1,752 Views)
Hi KB,
it's a rather simple VI, so you might be faster with rewiring:
Message 1290 of 1,444
(1,748 Views)
