10-26-2011 08:52 AM
I am in desperate need of this vi tree downconverted from 7.0 to 6.0. I Don't have access to the previous two version required to down convert. Is there anyone out there that could down convert this to v6.0 for me? You will be my hero!
Kevin Lyon
10-26-2011 09:05 AM
As has already been explained to you, uploading the .lvlib file, or uploading a "VI Tree" does not "automagically" include the subVIs. Just like in a text-based language, uploading one code file does not "automagically" include any other code file is "#include(s)". I have no idea of what use a VI tree would be to you without the subVIs, and if you had the subVIs, then it would be a trivial matter to simply re-create the tree.
10-26-2011 12:43 PM
Ahh...Now I understand what you were saying. Sorry about that. Here is the folder with everything in ver7.0. I need it converted to 6.0 (or at least the stuff that shows up in the tree file.) All of the required files should be in this zip folder as I can open the files and use them on a 7.0 machine.
Kevin Lyon
10-26-2011 04:24 PM
I need to convert a WIN Buffer to an Array. Could someone please convert this file from Ver . 8.0 to Ver. 7.1. Thank you
10-26-2011 04:31 PM
Kevin Lyon
Try the attached
10-26-2011 07:20 PM
Can somebody please convert these drivers from 8.5 to 8.2.
10-26-2011 10:46 PM
Thank you so much for the down convert and now I know what the tree file actually is! I am still at the beginning of the learning curve.
Kevin
10-27-2011 04:50 PM
Can someone please convert this 9.0 program to 8.2. Thanks
10-27-2011 08:50 PM
I need the file in LV7.1
KB29
10-28-2011 02:11 AM - edited 10-28-2011 02:12 AM
