Downconvert VI Requests
Can anybody please convert the attached VIs to LabVIW 2009?
SVG
Message 1371 of 1,444
(1,736 Views)
SVG
Attached. A few important comments:
  • The "My Basic Serial Write and Read" appears to simply be a copy of the shipping example. In this case there's no point in having the Boolean toggle switches.
  • The "My Basic Serial Write and Read" needs to be split up. You do not want to initialize and configure the serial port in each iteration of the loop.
  • The VI that looks for a numerical value can be replaced with the Match Pattern or Match Regular Expression function. There is no point in using that VI here.
Message 1372 of 1,444
(1,716 Views)
somebody help me, can you convert the labview 9.0 vi file to 7.1 vi file?
Message 1373 of 1,444
(1,707 Views)
Those VIs cannot be fully downconverted. They use VIs from a toolkit which cannot be downconverted. The VIs are fairly trivial. All they do is present a dialog to select a file, and then get the file extensions. Based on the file extension it calls the appropriate image file read/write VIs that are in the Graphics & Sound -> Graphic Formats palette.
Message 1374 of 1,444
(1,696 Views)
Can you convert me this library from Labview 7.1 to 6.0.
Many Thanks
Message 1375 of 1,444
(1,691 Views)
Can someone please covert the attached code to 8.6?  Thanks!
Message 1376 of 1,444
(1,690 Views)
Hi Lyuba77,
Here you go.. 8.6
Nitz
(Kudos are always Welcome:))
Message 1377 of 1,444
(1,675 Views)
Many Thanks
There were VIs from vi.lib included in the LLB (which should not have been in there). These were removed during the downconversion. You will need to replace the VIs with whatever existed in 6.0.
Message 1378 of 1,444
(1,667 Views)
Hi guys,
can anybody please convert me this VI to version 10?
Jimmy
Message 1379 of 1,444
(1,658 Views)
I haven't LV2011. I have 2010. Can somebody convert the vi? Thanks a lot of.
Message 1380 of 1,444
(1,654 Views)
