Downconvert VI Requests
@Jerry Jin wrote:
Do I need to convert a VI made with LV8.5 to LV9.0 so it can be used with LV9.0?
This thread is for requests of downconversion, not for general questions.
To answer your question, LabVIEW 2009 (9.0) can open a LabVIEW 8.5 VI. If you save it, it will be saved in LabVIEW 2009 format, and you will not be able to open it with 8.5 anymore unless you do a File -> Save for Previous in LabVIEW 2009.
Message 1391 of 1,444
(1,859 Views)
Is it possible to convert this VI from version 11 to version 9?
Thank you,
Gopinath
Message 1392 of 1,444
(1,855 Views)
Could I get the following 2010 project converted to 6.0 Project
Thanks!
source LabVIEW version 2010
target LabVIEW version 6.0
Message 1393 of 1,444
(1,851 Views)
Can somebody please convert the VI from 8.2 to 7.1, thanks.
Message 1394 of 1,444
(1,835 Views)
abhi
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1395 of 1,444
(1,833 Views)
Could someone please help me downconvert these VI's from labview 2011 to labview 2010. There are a couple in there and I've also attached a subVI library that these use. If not all then I could really just use the "readbinarydata.VI"Thank you!
Message 1396 of 1,444
(1,823 Views)
Please convert from LV8.5 to LV 8.2.
-Nate
Message 1397 of 1,444
(1,798 Views)
Message 1398 of 1,444
(1,790 Views)
Hi
Would someone be so kind as to down convert the Low_level_VI which I have posted earlier?
 It is quite an urgent project and I would appreciate the NI community's help at this point in time greatly.
Thank you,
Gopinath
Message 1399 of 1,444
(1,779 Views)
Message 1400 of 1,444
(1,775 Views)
