Downconvert VI Requests
@MichaelBowles wrote:
Could you please convert the LV 8.6 files to LV 8.5 files? I would really appreciate it!
Michael B.
Well, one VI isn't even finished, and the other one is just an example of a graph.
Message 381 of 1,444
(2,075 Views)
Thank you so much! I really appreciate it. Have a good weekend.
Message 382 of 1,444
(2,041 Views)
Attached is the driver in 6.1. The "Error Cluster From Error Code" VI that exists in later versions of LabVIEW does not exist in 6.1. You will need to create this yourself. I zipped it using 7-zip, as the archive was much smaller than regular zip (800K vs.  2.2MB). You can get 7-zip for free here: http://www.7-zip.org
Message 383 of 1,444
(2,034 Views)
Wow really appreciate this, thanks for your time and support. best regards
Message 384 of 1,444
(2,006 Views)
thank you
Message 385 of 1,444
(1,998 Views)
thank you.
Message 386 of 1,444
(1,995 Views)
If someone would kindly convert the attached file ...
from version 9.0
to version 8.5
... I would greatly appreciate it.
Message 387 of 1,444
(1,984 Views)
In LV8.5. A lot of missing subVIs...
Message 388 of 1,444
(1,981 Views)
There were some missing subVI's, mostly driver type stuff for a Newport.  So hopefully you have that.
Message 389 of 1,444
(1,980 Views)
Thanks so much for the fast response.
Kudos to both of you!
Message 390 of 1,444
(1,967 Views)
