Downconvert VI Requests
nagarjunapaleti wrote:
                      I forgot to attach the VI file. here i am attaching the VI file. Can you please convert the file. Thanks in advance.
Don't know if this will work for you...
Message 571 of 1,444
(1,829 Views)
hi,
can u please downconvert these ni modbus drivers for me.
source version is labview 7.1
and target labview version is 7.0
Message 572 of 1,444
(1,816 Views)
Hi!
Could anybody downconvert my Labview2009 data to Labview 7.0?
I have uploaded the file in hotfile, since i couldnt attach it in normal way because of the file size.
Link to data
Thanks in advance
Message 573 of 1,444
(1,771 Views)
Hi maam,
to reduce filesize you could use ZIP - atleast try to...
Then you should remove all those RubeGoldbergs (Comparing Booleans for Unequal to TRUE is the same as NOT!) and local variables (in the event structure you have old value" and "new value" terminals, the terminals of the booleans are unused...). Your upload is using LV2010 and not LV2009 as you said. And it is missing all subVIs...
I can only downconvert to LV8.0, it's attached...
Message 574 of 1,444
(1,765 Views)
Hi..
My VI has still not been down converted...if any1 can plz do it as soon as possible....because of that my work has been kept pending...
thanx a lot....
Message 575 of 1,444
(1,755 Views)
Hi saki,
did you asked your NI representative for a downconverted version of those "NI modbus VIs"? Don't you have the driver cd's that came with your LV7.0 installation?
Otherwise you have to wait for someone with LV7.1 still available nowadays...
Message 576 of 1,444
(1,754 Views)
Hi Gerd W,
Thnx for your reply.....
But i could not get the drivers along with my cd installation. I downloaded the nimodbus driver and the version available with it are only 7.1, 7.2,8.5 and 8.6
how could i then open this in labview 7??
Message 577 of 1,444
(1,747 Views)
Thanks GerdW, I didnt notice the failure part in the blockdiagram, until you point it out. Smiley Happy
Sorry, i have attached the wrong version, and i already tried to compress it in zip format, but there is no significant size reduction, it is still bigger than the allowed size.
For version 2009, I believe there is an option to save the data in old version( version 8.6-8.0). So there is no problem to convert with version 8. This time i have uploaded the project in version 2009 alltogether with the SubVI.
Thanks again!
New Link for Version 9
Message 578 of 1,444
(1,747 Views)
@saki wrote:
Hi Gerd W,
Try the attached. Not sure if they'll work for you.
Message 579 of 1,444
(1,736 Views)
HI,
         I am trying to execute the sample code from the NI.com using 1. Labview 8.5.1 & 2. smart camera NI-1762 from the link.
           http://decibel.ni.com/content/docs/DOC-9572, The link has all the downloadable files.
                                       2.Smartcamera_LABVIEW.aliases
                                       3.SmartCamera_LABVIEW.lvlps
                                       4.Acquire.vi
                                       5.Smartcamera_LabVIEW.lvproj
SO ANYONE PLEASE COULD HELP ME OUT TO RUN THE PROJECT USING LABVIEW 8.5.1 AND THE SMARTCAMERA NI-1762 IN WINDOWS VISTA-X64.
Thanks in advance.
paleti.
Message 580 of 1,444
(1,728 Views)
