02-19-2011 05:56 PM
If someone could downconvert the following, I'd appreciate it. The group that gave it to me uses Labview 8.5, but I think the .vi itself is written in 8.0. Unfortunately, I only have 7.1 available.
The drivers are available here if you need them: http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=12187
Thanks for taking the time to help out a stranger!
02-19-2011 08:53 PM
LabVIEW 7.0 drivers are shown as being available on IDNET:
02-19-2011 10:22 PM
Yep, I have the drivers. The .vi that I attached can't be opened in 7.1, though ('...error code 9 ... VI version (8.0) is newer....')
Thanks!
02-20-2011 11:26 PM
Can u downconvert to Lab view 7.1
02-21-2011 12:52 AM
Could you please convert the keithley labview drivers into 8.5 version.
I posted this once, but didnt get a reply.
02-21-2011 09:56 AM
Try the attached
02-21-2011 10:20 AM
Ran into a couple of issues:
02-21-2011 10:23 AM
Probably because you posted in this thread, and you're actually asking for an up-conversion, so the request should go here: Upconvert Requests Thread
I actually tried to do this, but ran into all sorts of problems. The project itself is messed up - everything in the project was pointing to non-existent VIs, and trying to repoint VIs to the library with a different name was an exercise in futility. Whoever created that project really messed it up. I would suggest you follow up with Keithley, as it seems that this is where it came from.
02-21-2011 01:02 PM
Can you please downconvert the following 8.6 file to 8.2.
02-21-2011 05:11 PM
Brilliant! Thanks!
...unfortunately, it's now demanding the conversion of two sub .vi's that I wasn't aware of before. Would you mind horribly converting these from 8.5 to 7.1?
Thanks again.
