Downconvert VI Requests
need this converted from
Labview 7
to
labview 6.1
Thanks Jeff
Message 771 of 1,444
(1,693 Views)
Labview 7
to
labview 6.1
Thanks Jeff
see attached
Message 772 of 1,444
(1,682 Views)
please can i have a down conversion from labview 10 to labview 9 version.
thank you
Message 773 of 1,444
(1,658 Views)
thank you
Message 774 of 1,444
(1,658 Views)
@o4enPro wrote:
Please can I have a down conversion from labview 10 to labview 9 version.
thank you
Here it is in LV9.  I only did the one file in your first message.  I'm assuming the duplication of the message and the attachments in the 2nd message is a mistake.
Message 775 of 1,444
(1,656 Views)
thanks a lot.
sorry for duplicating files, it is my first time i use the forum
Message 776 of 1,444
(1,653 Views)
Hi all,
Can anyone convert those drivers from 8.2.1 to 7.1 version?
Sorry for the number of files but Keithley's engineers seem to be tired...
Thanks a lot,
V.
Message 777 of 1,444
(1,646 Views)
Please could someone kindly downconvert the following .vis from version 8.5.1 to version 7.1?
Thank you very much
Sincerely,
Julia
Message 778 of 1,444
(1,628 Views)
@vloom wrote:
Hi all,
Thanks a lot,
V.
try the attached. I had to break the library apart in order to down-convert. Some of the VIs required name changes due to OS restrictions on allowed characters.
Message 779 of 1,444
(1,621 Views)
Thank you very much
Sincerely,
Julia
Attached in 8.5. You seem to be missing a subVI, "Convert-FORC".
Message 780 of 1,444
(1,618 Views)
