Downconvert VI Requests
@JCKey wrote:
I'm wondering if anyone could save both of the following VI packages back to version 7.1
http://sine.ni.com/apps/utf8/niid_web_display.down​load_page?p_id_guid=1C445FA0619D698AE0440003BA7CC...
http://sine.ni.com/apps/utf8/niid_web_display.down​load_page?p_id_guid=6E23DB10D9FC2B05E04400144FB7D...
8.2/8.21 to 7.1
thanks in advance
here's one...
Message 981 of 1,444
(1,922 Views)
8.2/8.21 to 7.1
thanks in advance
and here's the other. Since this one was project-style with a .lvlib, and neither of these exististed in 7.1, the downconvert renamed all of the VIs in the library.
Message 982 of 1,444
(1,921 Views)
@PCandelaria wrote:
Can somebody please save these files from ver 8.6 to ver 7.1 for me.  I need to use the Vibe Test file as an example on some stuff Im working on.  Thanks a ton!
Pat
Since you indicated you were using it as an example I am assuming you don't need the subVIs, which were not included.
Message 983 of 1,444
(1,917 Views)
thanks, that's a big help Smiley Very Happy
Message 984 of 1,444
(1,913 Views)
Correct.  I know the revision I posted is broken. I just need to open it in 7.1 to see how a couple things are wired.  Im doing something similar on another .vi Im working on.  I appreciate the help.
Message 985 of 1,444
(1,911 Views)
Dear all, I have a LabVIEW file in Version 8.5 and would like to convert to Version 8.2 so that I can use on the other computer.  Would you please do it for me?  I am not able to access the computer with 8.5 anymore....
Thank you so much.
Message 986 of 1,444
(1,911 Views)
Thank you so much.
attached
Message 987 of 1,444
(1,902 Views)
Message 988 of 1,444
(1,888 Views)
Can anyone help me to convert this VI from ver.8.5 to ver.7.0? I need to use this file on other computer only with Labview 7.0. Thanks.
chienlin8997
Message 989 of 1,444
(1,878 Views)
chienlin8997
The "target" subVI is missing.
The code: ummmm... wow.... that code really needs to be redesigned.
Message 990 of 1,444
(1,872 Views)
