Dr. Damien's Development - Memory Allocation in Loops
altenbach wrote:
This is one of my standard templates. You can find many instances here in the forum. 😄
Searching for those standard templates.  Does anybody (everybody) actually use these methods?  Are there replacement subVIs?
Message 11 of 17
(2,587 Views)
I always thought that the inner workings of LV already implement the algorithm of ManagedAddItems.vi (doubling the allocated memory each time we run out of it).
That 'knownledge' is based on my early beginnings using LV 5.
Felix
Message 12 of 17
(2,566 Views)
They don't and it's the delete elements which is more time consuming.
Are there some standard VIs ppl use to implement the techniques discussed?
Message 13 of 17
(2,555 Views)
The "Filter 1D Array" function in the OpenG library does not use this technique either... it is comparable in performance to the 'SimpleRemoveItems.vi'
Message 14 of 17
(1,862 Views)
It was pointed out in 2007 that the openG version of "delete elements from array" is slow and inefficient. I wonder if it ever got improved... See here for details (read the entire thread for my even better code!)
Message 15 of 17
(1,849 Views)
Here's an even more up-to-date thread about the OpenG Array functions.  There were a bunch of updates proposed to make them faster.  I'm not sure what the status is on getting the library released though.
http://lavag.org/topic/15980-openg-filter-array-revised/
GCentral
Message 16 of 17
(1,823 Views)
As you upped this thread I tried the same benchmark with the conditional tunnel.
Here are my results.
Bucket: 11 ms
LV2012 conditional tunnel : 87 ms
Managed: 107 ms
SimpleAdd: 179 ms
SimpleRemove: 8330 ms
Message 17 of 17
(1,809 Views)
