Dr. Watson Dr. Watson C0000005 access violation Win NT4.0 and LV7.1
Hi together,
I got an error "Dr. Watson C0000005 access violation" after closing my LV application.
LV 7.1 and Windows NT 4.0 SP6a .
 Dr Watson
Does anybody has an idea?
Thanks.
Message 1 of 14
(5,530 Views)
I tried also with update to LV 7.1.1. ,   without success.
Message 2 of 14
(5,522 Views)
Ich got this error message after disabling Dr Watson.
Error Message
May be this is a LV 7.1 bug?
Message 3 of 14
(5,512 Views)
What makes you think it's a LabVIEW bug? I'd be more inclined to think it's something within your code. Are you accessing hardware? Are you calling DLLs? Without knowing what your program is doing, you can't say one way or the other.
Message 4 of 14
(5,503 Views)
I don't use hardware and no dll is called. I can focus then problem on a part of the program which handles a Systray Icon.
http://home.arcor.de/raena2/LabVIEW_Tray_Icon.llb
So just using the sample in this llb shows the probelm when closing the application.
Message 5 of 14
(5,499 Views)
strange thing: if I insert a waiting time between closing the systray icon and exiting the program,
no Dr. Watson and no error message comes up.
Does anybody has an idea what the reason could be for this behavior?
Message 6 of 14
(5,470 Views)
Hi there
add a Destroy user event" after the unregister event function for each user event in your code.
You are calling external code (axsTrayIcon.ITrayIcon COM-Object), this code may cause the problem.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 7 of 14
(5,457 Views)
Thanks chrisger, but this doesn't help. Same Error Message.
Any other suggestions?
destroy
Message Edited by maximint on 12-12-2008 08:32 AM
Message 8 of 14
(5,449 Views)
The way you've wired that it won't do anything. UsrEvtRef is only valid inside the event case. When you tunnel it out it like that its value is lost, and is therefore meaningless. I suspect your problem has to do with those external calls that you're making with the systray. Those VIs call Windows DLLs. Why don't you try removing them and see what happens?
Message 9 of 14
(5,440 Views)
This is wrong. The tunnel of the user event through the event structure is filled with data only in the UserEvent event case,  but this case will not stop the while loop, so the tunnel through the while loop is always NULL.
Pass ALL user events created inside "Register Tray Icons Events.vi" to the outside and destroy them after the destroy event registration.
Best regards
chris
Message 10 of 14
(5,439 Views)
