Dr. Watson Dr. Watson C0000005 access violation Win NT4.0 and LV7.1
I think I understood your answer and wired the "destroy(s)" like recommended by without success. Same error.
Any other idea?
d2
Message Edited by maximint on 12-12-2008 09:40 AM
Message 11 of 14
(1,105 Views)
@smercurio…
yes I removed them already and the problem is gone. So the reason for this problem has s.th. to do with this  systray VIs.
But I want to have this functionality. The interesting thing is that the problem doesn't occur if e.g. WinXp is used or a wait time
is set between closing the program and exiting.
Message 12 of 14
(1,097 Views)
d3
Message 13 of 14
(1,091 Views)
I don't understand what the "d3" screenshot is supposed to show. Since your problem went away when you stopped using that library, then you may want to follow up with where you got the library to find out about issues with using it under NT. Other solutions:
Message 14 of 14
(1,073 Views)
