Drag and drop and right clic on graph incompatible?
I found a little problem on the way that labview propose to manage the drag and drop on graph. When the algo of drag and drop is set, the right clic don't work on the first time. You can see this problem by yourself on the exemple given by Labview on "C:\Program Files\National Instruments\LabVIEW 2015\examples\Structures\Event Structure\Drag and Drop - Initiating a Custom Drag.vi". If someone have a way to avoid this problem that will be great.
(3,274 Views)
Accepted by topic author sklod
if you to the handler of "Mouse Down" event you can add a condition to set the "Mouse Down?" boolean only when left button is clicked. Something like this:
In this case when you right click the program will not go into the "True" case of "Mouse Leave" handler and display the right click menu properly.
(3,246 Views)
I didn't see that one.
Thanks a lot
(3,219 Views)
Glad I could help 🙂
(3,217 Views)
