Drag and drop path from explorer adds a null character at the end of path
Hello, weird thing in LabVIEW 2021. After allowing Dropping on Path Control, when you Drag and drop from File Explorer or Total Commander, the resulting path has null at the end so I have to sanitize it manually otherwise it causes trouble. It definitely was working fine at some point in the history in LV. Do you have same problem? Am I not seeing something I should?
Vit
(1,633 Views)
Accepted by VitSlaby
(1,619 Views)
I mean, Fixed in the LabVIEW 2021 SP1 f2 Patch.
Certified LabVIEW Architect
(1,615 Views)
