Dragging & Dropping FPGA Item on Diagram hangs LabVIEW
I have LV2021 32bit with the FPGA Module 2021 installed.
Every time I drag & drop an FPGA item (FIFO, Memory, Handshake, Register, IO…) from the project explorer to a diagram, LV hangs forever (at least 15min) and I have to kill it.
I expect it to create a method node with the default action depending on the item type, but it fails miserably.
Could that be a bug of the FPGA Module? How can I fix that?
Raphaël.
(1,440 Views)
I have not experienced this, could you post code so others can try to replicate?
Otherwise you can reach out to NI support and they will provide feedback or a bug report.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,413 Views)
No specific code needed: new project, new FPGA target, new FPGA item dragged and dropped onto a new VI's diagram -> LabVIEW hanging.
I will contact support about this issue and post here if I find a fix.
(1,400 Views)
Tried on the same configuration and am not getting any issues.
ALE Consultants
(1,368 Views)
I also tried with LabVIEW 2021 SP1 (32-bit), connected to a myRIO (which shows up in MAX).  Had no problems getting a new FPGA and populating it with random Controls, Indicators, and FPGA I/O ports.
Bob Schor
(1,353 Views)
