How to set Execution Options and File pathname when creating sequence file by using TestStand API
I'm creating a sequence call in LabVIEW by using TestStand APIs.
I created a sequence file and sub-sequence in the file.
In the sub-sequence, I inserted the SequenceCall step but I want to set those configurations as well in LabVIEW.
How can I set the configurations in LabVIEW? I got the Module reference from this sequence call step but there's no setting to change pathname and execution options.
Thank you
(1,491 Views)
I fixed it by using SequenceCallModule
(1,451 Views)
