Drain a 3V coin battery with Labview to test the lifetime of the battery?
For what does the 0s and 1s stand for? and how I can add that into labview. I am confused
Message 31 of 36
(1,843 Views)
0 = L
1 = H
I do not have DAQmx available so I cannot give you details.  Most digital output VIs will accept either booleans (T or F) or integer numbers as inputs.  Some will accept arrys of booleans or numbers.  You have to look at the drivers available for your devices and work from there.
Lynn
Message 32 of 36
(1,827 Views)
What kind of Pulse generation do I need?
Like buffered pulse generation?
Message 33 of 36
(1,812 Views)
Nice.
[will work for kudos]
Message 34 of 36
(1,761 Views)
Accepted by topic author blade2008
Hi blade,
You may want to check out this KnowledgeBase for information on how to generate a pulse of a specific pulse width and high/low pattern.  Here, you are using the onboard counters to act as the timing source of the digital signal that you're generating.
Sara Lewandroski
Applications Engineer | National Instruments
Message 35 of 36
(1,710 Views)
Thanks Sara
Message 36 of 36
(1,701 Views)
